TCS SS brake line kit
I ordered one of these kits from Goodridge a while back and was starting to do the install of it. The car has Traction Control so I ordered as such. The problem is that it only came with 5 lines, and the rear system has two lines for the traction control and two lines for the calipers. The front just has the two lines for the calipers, but that is six lines needed not 5. Has anyone else had problems like this, or does this fifth line go somewhere else??? The repair manuals are not helpful, saying that it cannot be done without the Tech1 tool then not explaining any further.
Called goodridge, and Mike Klapp said that the line is not there, but is before the brake lines separate all the way up by the transmission. just thought I would share since I found out which one it was.
Jan 23, 2015 01:13 PM
squarehead
Jan 15, 2015 07:02 PM
CARiD
Dec 26, 2014 04:20 AM
