TCC lockup switch doesnt work
Old Feb 28, 2004 | 12:46 AM
Robert95z's Avatar
Hmm.. Does this mod work for all LT1s? I spliced the tan/black stripe wire on the RED pcm connection. Grounded it to the Cig lighter ground, and even grounded it to varous screws in the car after realizing it wasnt working. Any ideas why this isnt working?
-Robert
Old Feb 28, 2004 | 02:33 AM
Prorac1's Avatar
Unless the 95s are goofy, You need to tun the wire to a two position toggle switch (on/off). Run the wire that you spliced into the brown and tan to one side, and run a ground to the other. When i had mine, i grounded it to the shifter mounting bolt. Hope this helps, Prorac1
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Jan 23, 2015 01:13 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
