tb-intake port help
Old May 11, 2011 | 01:54 AM
twistedbowtie's Avatar
Question tb-intake port help
i bought a 58 mm tb and was gonna port the two holes on intake to match bigger gasket for the 58mm. i useualy use stones in my drimel tool. what other ways could i do it that grinding stones? thanks
Old May 11, 2011 | 02:38 AM
chevy_dude97's Avatar
Re: tb-intake port help
a burr for alluminum should work the best.
Old May 11, 2011 | 03:50 AM
Red_94Formula's Avatar
a carbide burr is the best choice
Old May 11, 2011 | 04:45 AM
RamAir95TA's Avatar
Hopefully you're not going to be porting the manifold on the car without taking some extreme precautions.
Old May 11, 2011 | 11:53 AM
You can do it on the car. put some rags in their. Even if the aluminum metal flakes get sucked into your chamber they will burn right up. Even if the small impossibility they dont burn who cares they will go right through your motor and out the exhaust
Think im nuts? Ive seen small rock pebbles deliberately placed down a running motor at mid rpm and watched fly them out the exhaust.
Old May 11, 2011 | 12:18 PM
RamAir95TA's Avatar
This is the most ridiculous thing I have ever heard.
Old May 11, 2011 | 12:20 PM
no i wouldnt do it with the intake on the car. i have it off. butwhere can a find a carbide burr?
thanks alott guys
Old May 11, 2011 | 12:30 PM
RamAir95TA's Avatar
thanks alott guys
Just about anywhere really. I use www.mcmastercarr.com. I have also done it with a coarse 1" sanding drum; it makes for a rounder hole.
Old May 11, 2011 | 01:06 PM
okay thanks joe.
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
bunker
Aug 31, 2015 01:46 PM
bunker
Aug 1, 2015 09:47 PM
