tb bypass without a kit
Old Dec 10, 2003 | 01:01 PM
camaroguy94's Avatar
anyone know where u can get the piece to connect the tb hoses without having to buy a kit?
Old Dec 10, 2003 | 01:08 PM
FastZinTennessee's Avatar
I didn't need any parts for my car....... I took the hose that goes from the top of the radiator to the throttle body and jumped that hose to the metal pipe coming from the back of the motor to the throttle body.
Old Dec 10, 2003 | 01:12 PM
94 CAMRO Z28's Avatar
On my '94 I simply cut the hose off the TB tube since it was stuck on, then I used about a 3in. section of copper tubing...I think 3/8in..... A little clamp from a hardware store on each end and all done. There is no need to plug the holes on the TB. Should be able to do it yourself for a couple $$ at most.
Aaron
Old Dec 10, 2003 | 01:30 PM
RallyRed701/2's Avatar
i got a 3/8" barb from a hardware store for like $2.50, and then i reused the clamps that were already used for the hoses... if you didnt want to reuse those you coud have gotten new ones for a couple cents prolly.... it was cheap... but it was still a pain in the ***...
Old Dec 10, 2003 | 01:41 PM
Heatmaker's Avatar
Advanced Member
pep boys has the 3/8 inch copper hose $2.50 and get the 3/8 inch rubber caps while your there. Total $3.50....No need for a kit the kit is just the same stuff
Old Dec 10, 2003 | 09:22 PM
Bud M's Avatar
That's because you have a 95. On 93/94s you pull the hoses off the tb and join them together with a barbed connector like RallyRed said.
When you do it, be sure to put towels under the tb so you don't pour coolant on the opti. Bleed the cooling system when you're done.
Old Dec 10, 2003 | 09:37 PM
revtime's Avatar
I had enough parts left over from my B&M tranny cooler to do my TB bypass.
Thank You B&M.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
CARiD
Jan 27, 2015 06:27 AM
Jan 23, 2015 01:13 PM
