TB Bypass...or not
Old Feb 9, 2004 | 04:29 PM
Zulu-Two-Eight's Avatar
TB Bypass...or not
I have a coolant leak in the rubber hose exiting (I assume it is exiting) the throttle body (the hose on the Pass. side). Since I have no other mods, am I better off getting the replacement hose or doing the TB bypass?
On an unrelated note......anyone in the NY/CT area know where to find Seafoam? I've tried Carquest, Advance, Autozone, NAPA (in Mass)...I can't find it anywhere.
Old Feb 9, 2004 | 04:38 PM
drewstealth's Avatar
Yes just do the bypass. It won't hurt anything. It can only help. It is also a proven 5hp.
Old Feb 9, 2004 | 04:40 PM
EbeZ28's Avatar
Bypass it. You don't need it, and you'll get a few ponies back when the engine is heat soaked...maybe 6ish rwhp.
Old Feb 9, 2004 | 04:41 PM
QCKZ28's Avatar
there isnt really a reason not to do it...
just do it!
jesse
Old Feb 9, 2004 | 04:43 PM
Red96Lt1's Avatar
In Alabama, I get my seafoam at NAPA. Also on the bypass, depending on what hose is cracked, you may need to replace it for the bypass.
