Talk About A Funny Way To Improvising To Remove My Crank Hub Lol Pics Inside
Old Jan 5, 2008 | 12:24 PM
playa7970's Avatar
had to go out and buy 3 7/16 screws with nuts to go along with it then when i got home i found out that the bolt heads were to small and had to use wrenches i had laying around to hold the bolts from falling through finally got it out thanks for all the help anthony
Old Jan 5, 2008 | 12:42 PM
Don 97 SS's Avatar
Ha ha that last pic expresses my sentiments exactly regarding that crank/hub design that is such as PITA to remove.
Old Jan 5, 2008 | 12:53 PM
playa7970's Avatar
lol how come i cant get this seal off?
Old Jan 5, 2008 | 09:05 PM
sam pace's Avatar
Damn, I've always used old head bolts.
Old Jan 5, 2008 | 09:11 PM
ulakovic22's Avatar
Since you've got the hub and opti off you should just take the timing cover off and you can use a chisel and tap them out from behind. That's the easiest way. Not sure of the best way to do it in the car.
Old Jan 6, 2008 | 01:53 AM
ZX636RIDER03's Avatar
Looks like you need a sleeve to go over that hub to fix that groove that the seal created. I had to take my hub off three times to figure out where the leak was coming from and it wasnt the seal that i had to replace it was that minuet little groove. My opti also needs to be replaced cause theres a groove on that too.
Old Jan 6, 2008 | 01:56 AM
Green96Z's Avatar
There is a special tool for pulling the front seals. It has a long handle and 2 curved talon-like hooks on it. Autozone carries them. If you don't need to pull the front cover, don't. Otherwise you have to drop the oil pan enough to pull it off.
actually it may not have a groove, i must be halucinating from all those time that i had to pull mine off
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
Queens94z28
Dec 20, 2014 09:11 PM
omarECD
Aug 19, 2002 07:28 AM
