taking out headlight motor
Old Jun 6, 2003 | 01:03 PM
clownhair's Avatar
I am taking out the headlight motor on my 97 firebird, it is making a grinding noise when i shut it off, and am in need of some assistance.
I see 3 bolts holding the motor on but then there is the rod coming off the motor to the headlight that I cannot seem to disconnect. Anyone who knows please help me.
Old Jun 6, 2003 | 01:28 PM
clownhair's Avatar
n/m I got it with some wd40. Headlight sounds much better now.
Old Jun 6, 2003 | 07:11 PM
fbird95's Avatar
Yeah there is also a bolt going from the motor to the arm to the headlight. You can try the free headlight fix, which involves rotating the gear 180 degrees. you can see how it works on this site, www.bfranker.badz28.com/headlightfix/index.htm , this is a good temporary fix, or you can replace the entire motor, or just the gears, the same site sells brass gears to retrofit the plastic ones.
Old Jun 6, 2003 | 11:29 PM
clownhair's Avatar
yep, thanks I found that sight earlier and flipped it 180, when it goes again i will get the brass gears.
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
Darth Xed
Jul 1, 2002 03:22 PM
