Tach Install
Old Nov 3, 2004 | 01:24 PM
aintno6's Avatar
Tach Install
Hey folks, I need some tech help here with my 97' Formula (A4). I want to install this Autometer tach in my car. But... I have never installed a tach before. I dont have the stock coil setup (running delteq unit now), so I dont know if that changes anything. I'm pretty good when it comes to wiring though.
How hard is this too install? What wires do I need to tap into?
Thanks in advance,
Mike
Old Nov 3, 2004 | 01:29 PM
93turbo5oh's Avatar
Re: Tach Install
why not just install a shift light?
Old Nov 3, 2004 | 01:32 PM
aintno6's Avatar
Re: Tach Install
Because its an auto, it upshifts on its own. A shiftlight is like a warning to tell you to shift. Well I dont have a manaul valvebody. So it wouldnt work for me.
mike
Old Nov 3, 2004 | 01:46 PM
camaroKid223's Avatar
Re: Tach Install
unbolt the ecu and look for white wire #13 on the RED connector, then just get a wire tap and tap right into it. for ower supply i got mine from the fuse panel, light i connected to the power for the parking and headlights, then just ground it under the dash.
Old Nov 3, 2004 | 02:25 PM
aintno6's Avatar
Re: Tach Install
TY, looks like the only hard part is routing the wires. I'll prob just route it through the factory spot.
Mike
Old Nov 3, 2004 | 03:42 PM
aintno6's Avatar
Re: Tach Install
I was just wondering, does that wire run under the dash? If so, I'll just tap it off there, instead of at the pcm.
MIKE
Old Nov 3, 2004 | 03:54 PM
Re: Tach Install
i think it does because i have heard of people tapping in under the dash. i just routed mine behind the weather stripping and in the door jam works fine and you cant see it.
Old Nov 4, 2004 | 08:37 AM
aintno6's Avatar
Re: Tach Install
Awsome,
Maybe I'll do some kind of a install guide for people who have never done this before.
Mike
Nov 18, 2023 07:21 PM
mr28
Apr 20, 2016 05:44 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
