Tach Install
Tach Install
Hey folks, I need some tech help here with my 97' Formula (A4). I want to install this Autometer tach in my car. But... I have never installed a tach before. I dont have the stock coil setup (running delteq unit now), so I dont know if that changes anything. I'm pretty good when it comes to wiring though.
How hard is this too install? What wires do I need to tap into?
Thanks in advance,
Mike
Thanks in advance,
Mike
Re: Tach Install
unbolt the ecu and look for white wire #13 on the RED connector, then just get a wire tap and tap right into it. for ower supply i got mine from the fuse panel, light i connected to the power for the parking and headlights, then just ground it under the dash.
