T/A Tech question(oil press & steering)
Old Feb 10, 2005 | 10:52 PM
hektyk's Avatar
Well I bought a new T/A Today, a 95 auto and I have a prob. I don't know if this is nornal but my oil pressure is at around 15 psi when idleing at around 600 rpm, when I hit the gas or I'm just cruising at like 1100 RPM It's around 40 psi. Is it normal to run that low of a psi at idle. Also te steering is acting kinda funny. Basically it pulls a little to the right sometimes and then back to the left and just kind of "wonders" Mainly it's at lower speeds like between 20 and 40???? Also can someone tell me where the RPO codes are listed at.
Any help regarding this matter will be greatly apprieciated (sp).
Thanks Guys, Hektyk
Old Feb 10, 2005 | 11:06 PM
Re: T/A Tech question(oil press & steering)
Oil pressure sound fairly normal. The cars also tend to follow ruts with the big tires they have on them (more so if underinflated). The type of tire can also be a factor.
RPO codes are in the glove box.
Old Feb 10, 2005 | 11:21 PM
hektyk's Avatar
Talking Re: T/A Tech question(oil press & steering)
You are the man. Thanks alot
HectorM52
Jul 30, 2017 11:46 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
Caps94ZODG
10
Sep 9, 2002 12:08 AM
!!!TED!!!
Aug 27, 2002 05:41 PM
