Symptoms of optispark failure
Old Sep 14, 2005 | 02:34 PM
Paul87's Avatar
Well, my car will start up and run fine until I shut it off and turn it back on while its hot. Then I get a rough-*** idle, car misfires, and you can actually feel the car lunge forward little bits at a time when you take your foot off the brake. lol.
So I'm pretty sure this is an ignition failure regardless, but I thought once and opti failed the car wouldn't be driveable anymore, not a slow process
Old Sep 14, 2005 | 06:55 PM
crazypurgatory's Avatar
Lightbulb Re: Symptoms of optispark failure
It sounds like it might be the ignition control module.
I'm not 100% but you sould check it out.
Chris G.
Old Sep 14, 2005 | 08:16 PM
My Iroc Z28's Avatar
you would get a trouble code if it was the opti.
Old Sep 15, 2005 | 12:45 PM
Paul87's Avatar
Even on OBD1?
Old Sep 15, 2005 | 12:54 PM
Paul87's Avatar
Also, could it be a faulty ICM or a good one that's getting too hot?
Old Sep 15, 2005 | 01:12 PM
Yes even on a OBD1.
I remember when the ICM was going out on my 1985 camaro.
The OPTI spark might not set a code even if it's bad.
On the OPTI spark it all depends on what part fails.
And yes it could it be a faulty ICM or a good one that's getting too hot.
You sould be able to check the ICM at a autoparts store.
I know there is a tester for the old ones like in the 85 camaro I had.
Not sure on the new camaros.
Chris G.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
tdigger9899
Sep 7, 2015 10:56 AM
