Symptoms of a bad map sensor
Old Feb 27, 2004 | 06:57 PM
acslinger2525's Avatar
What does the map sensor do? What are the effects of a map sensor failing? Thank yall
S.C. Smith
Old Feb 27, 2004 | 09:03 PM
Basically, it senses the engine load via vacuum. Sluggishness and poor gas mileage would be a couple of symptoms of a bad sensor. They don't go bad very often, though.
Old Feb 28, 2004 | 07:49 AM
I thank you for the info. I may change it, because i am one of those people with the mystery skip from idle to 2500. I thank you again
S.C. Smith
Old Feb 28, 2004 | 09:59 AM
cndctrdj's Avatar
i just had to replace mine, litterally 3 days ago. the check engine light comes on when they break and my car seemed to be missing a piston. it had no power in 6th gear. when it was good i could drive my car in 6th at 40 mph no prob. when it was broke i couldn't do 60 in 6th. its a huge difference for such a little part.
Old Feb 28, 2004 | 05:25 PM
I changed it, no difference
Old Feb 28, 2004 | 05:43 PM
RedHottG2's Avatar
Make sure your coil wire didn't pop off.
Old Feb 29, 2004 | 09:21 PM
YOUNGGUN96's Avatar
can a map sensor make one backfire and stuff?
Old Mar 1, 2004 | 08:59 AM
cndctrdj's Avatar
change the egr valve too i was told they both go at the same time. i also had to replace mine about two weeks ago
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
Fatdog2
Feb 13, 2015 08:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
