switching to vented opti
Old Nov 18, 2005 | 03:10 PM
hallbilly's Avatar
NAL-1104032
What else will I need to convert to the non-vented to the vented?
thanks
Old Nov 18, 2005 | 04:48 PM
Dave89IROC's Avatar
Re: switching to vented opti
to go to vented, you need the opti, the timing cover, the opti harness's(wiring and vacuum) and a longer dowel installed in your cam, or a cam for a vented opti
Old Nov 18, 2005 | 06:32 PM
hallbilly's Avatar
k thanks man... i would have searched for it... but I didnt have much time to do it at work.
Old Nov 18, 2005 | 06:36 PM
cmerc's Avatar
http://www.moreperformanceinc.com/in...t_1=Optisparks
This is a link to More Performance, they make a conversion kit Optispark conversion kit for 92 - 94 Fbodies I have one on my 94Z and recomend it.
Old Nov 18, 2005 | 06:54 PM
Originally Posted by hallbilly
NAL-1104032
thanks
http://para.noid.org/~muttvette/opti.html
Old Nov 22, 2005 | 11:41 AM
hallbilly's Avatar
is the electrical harnes needed, or would it be easy to make the original work?
Old Nov 22, 2005 | 11:42 AM
hallbilly's Avatar
Holy crap... gmpd.com wanted 57 bucks for s&h on just the opti alone! WTH
Old Nov 22, 2005 | 03:57 PM
Dave89IROC's Avatar
It is needed, if you get all the parts yourself,
This
is the cheapest I've found it, and I would recommend new, just for the fact that these do corrode
Old Nov 22, 2005 | 06:12 PM
cammed_aro Z28's Avatar
i did not buy an electrical harness when i converted mine, i went to the dealer and bought the plug end (plastic piece) only for $3 and change, my dad is good with electrical and pulled the pins out of the old plug and re attached the wires to the pins in the new plug, took about 20 minutes and only $3
Old Nov 22, 2005 | 06:53 PM
SPEED750's Avatar
Dude, screw all that parts crap. I've seen a vent kit that you ad on to your nonvented opti. I know mid-america sells them for LT1 vettes ($14). Basically it's just a plastic piece and a rubber hose that you hook to intake vacuum. The other end goes to the bottom of the opti. I think the non-vented has 3 small holes in the bottom. You drill out one hole and connect the vacuum line. I can't remember if you plug the other holes or not. Try a web search, I think GM high-performance mag did a write up as well.
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
thenewkid
Nov 27, 2014 09:41 AM
