Switch To Carb 94 LT1
Re: Switch To Carb 94 LT1
Originally Posted by Z95m6
You probably aren't gonna get much help now that you have a bad reputation on this site for screwing someone over.
Please read the retraction under FS.
If you're not smart enough to find it your loss.
John
Z95M6--You probably aren't gonna get much help now that you have a bad reputation on this site for screwing someone over.
Couldn't agree more.
oh well. Someone is having a hard time here.
Originally Posted by OldSchoolSS
Well I haven't posted in a while since I've been in communication with John Leach AKA black cloud tonight he sent me back some money to cover the difference of a pII and a P III he also is going to help me get the software working. He also is trying to line up a pentium III laptop from one of his friends for me. Thank you John for working with me!
Thanks again to John and everybody else! My faith in mankind has been restored & I'm not talking about the wrestler either.
See ya around.
BC
John
John
My life doesn't revolve around this site to continually keep up with every post. I did see how you were acting in that post and how you were threating other board members. Threating other board members isn't to cool. I believe Dmoss69 you sent a threat to in a PM' he posted. I was just letting you know that for the most part this is a community and the members usually don't help out people with attitudes like yourself. By the way if YOU were smart enough you would just go to a parts house and measure an opti seal there, and then get a freeze plug based off the measurement.
yes GM makes the opti block off plate...i got mine through scoggin dickey for 25 bucks...part number 12367600 now its 48?? thats retarted...you cannot use a freeze plug becasue the seal is rubber...this plate fills that hole and bolts to the timing cover
i don't understand why you couldn't use a freeze plug. You just pull the seal out and put the freeze plug in its place. The only way it wouldn't work is if it was a real oddball size.
