swiching oil- What do you use in your 100K+
Old Aug 3, 2004 | 12:18 AM
Zulu-Two-Eight's Avatar
My 96 Just turned 100k. I want to start using synthetic. Is it a good idea to change the type of oil on an old engine? Should I use a blened oil for the first few oil changes, then switch to a full synthetic?
Old Aug 3, 2004 | 12:43 AM
CoUnTryMuZiCZ28's Avatar
Re: swiching oil- What do you use in your 100K+
I switched my oil half and half on one change then went to full synthetic on the next.. I like the mobil oil, not mobil1, just mobil.. Its in a white bottle with a green cap.. Its a high mileage formula and its a 10w30 which is what i have always used on my car, I feel its best for it.. But I like what mobil advertises that it keeps seals lubricated and conditioned and cleans deposits.. Try it out.. I love that stuff.. I think its one of the only high mileage formulas that come in synthetic. Its only like 2.50 each qt..
Old Aug 3, 2004 | 12:51 AM
RED95LT1Z28's Avatar
I use mobil 1 10w30. I have 114k on my car and when i switched i did a half and half change and then i went to four quarts synthetic and one quart regular and then to full synthetic. I do use the acdelco filter not the mobil 1.
Old Aug 3, 2004 | 12:52 AM
SnakEaterZ28's Avatar
i use redline 10w30 in mine..love it!
Old Aug 3, 2004 | 01:03 AM
LeftoverChinese's Avatar
Mobil 1 0w40 based on the recommendations of Patman. Works good for me. I also use the Larger oil filter.
Old Aug 3, 2004 | 06:29 AM
ptowngn's Avatar
i've used castol syntec for quite a while now. I've always understood NOT to switch to synthetic on a 100k mile plus car do to the fact that synthetic will seem to find all of the leaks.
I have used castrol syntec and love it. I drive the **** out of the car when i do drive it, and i still have about 60lbs of oil pressure when i start it up and right about 35 at idle when the engine is hot.
Old Aug 3, 2004 | 08:16 AM
Thanks alot. Sounds like I'll go half and half for awhile, with 10w30.
Old Aug 3, 2004 | 08:47 AM
94Zpower's Avatar
Royal purple 10w40 as recomended by Patmanalso.
Old Aug 3, 2004 | 06:12 PM
Spinner's Avatar
I also run mobil 1 0-40 based on my own results, and those of other local F-bodies. It's good stuff.
Old Aug 3, 2004 | 07:05 PM
Steve in Seattle's Avatar
Mobil 1 10W30 year round (I'd use 5W30 if I still lived in Saskatchewan).
PF35L sized filter (extended capasity and bypass-valve).
180,000 miles on the engine with no problems so far. (original opti!)
Old Aug 3, 2004 | 08:39 PM
grygst76's Avatar
Mobil-1 5W-30
Old Aug 3, 2004 | 09:22 PM
LameRandomName's Avatar
Just switch 100%.
The only isue with synthetic on a 100,000+ mile engine that has been run on dyno oil is that it tends to clean out the sludge from the engine. That means two things; One, you want to change the filter (not the oil), at 500, 1000 & 3000 miles. Two, if there was a leaky gasket somewhere that was plugged with sludge, the synthetic is likely to uncover it and it'll start leaking.
Jus so you know, I switched to Amsoil in everything I own several years ago, and I only change my oil once a year now. I still have to change the filter every 3000 miles of course, but I'm still saving a bundle.
On your engine, because of it's age, I'm going to say that a nice 10-40 synthetic would be good for you. Don't go to a 20-50... too thick.
blubird
Oct 29, 2010 07:38 PM
eww18
Jun 22, 2006 08:22 AM
95 N2OT/A
Apr 8, 2006 08:26 AM
User56898
N2O Tech
11
Jan 17, 2006 10:24 PM
scottslt1z28
Dec 19, 2005 05:04 PM
