SVO Injectors Install
Old Jun 6, 2004 | 02:48 PM
95RagtopTA's Avatar
OK, thought I would do something REAL simple today and install my SVO injectors but, like everything else, I've run into a snag. Those little metal clips that fit the stock injector to the fuel rail are not fitting on my SVOs. Are they really needed? I've tried to bend them every which way but nothing works.
Old Jun 6, 2004 | 02:52 PM
ibanez6rg's Avatar
A lot of people run fine without the clips and have no problems at all. Mainly because the fuel rail is bolted down on the intake.
Old Jun 6, 2004 | 02:54 PM
Spinner's Avatar
What he said. To hell with those stupid clips
Old Jun 6, 2004 | 03:05 PM
95RagtopTA's Avatar
Didn't think it would be a problem not using them--just wanted to be sure. Thanks for the replies!!
Old Jun 6, 2004 | 04:50 PM
BlackbirdWS6's Avatar
thats pretty weird, mine went on without a problem going from stock to SVO #30's....i dunno man, sorry to hear bout the bad luck but it wont be a problem anyway
Old Jun 6, 2004 | 04:52 PM
96Z28Guy's Avatar
Mine went on with the clips..
36# SVO Blue Top Injectors
Old Jun 6, 2004 | 06:24 PM
95RagtopTA's Avatar
After doing a couple searches, I found that other people have had this problem. The reason there's a problem is because these and other aftermarket injectors do not have a full groove around the injector. Instead there are two breaks in the groove, one by the electrical connection and one on the opposite side. Our clips are not long enough to go over these "raised" parts of the groove. Most end up not using the clips, however because I'm so damn **** about this stuff I just used my dremel to knock out the outter "raised section" of the injector--the clips then slid right in .
Old Jun 6, 2004 | 07:19 PM
TenaciousZ's Avatar
I just threw those clips away when I went with the 30#'s. easier to take off without em
rje
Sep 9, 2002 12:35 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
