SVO injector question
I am tring to install some 30# Ford SVO injectors, but the grooves in the injector, where the clip goes, dosen't go all the way around. There is a grove on each side, but with the injector facing the right way the groves are at a 90* difference from the sides of the clip.
How do I clip these injectors down to the fuel rail?
Do I carve out the groove all the way around?
Joe
Joe
Re: SVO injector question
There is another groove, but the injector would have to be pulled out some in order for the clip to go around it. I thought that it would possibly cause a leak at the fuel rail by not having it in all the way. Somebody let me know if I am wrong.
You can use the other (i.e. continueous) groove even though the injector will not sit as deep in the fuel rail as the stock injectors do. That's the way I installed mine, and they haven't leaked yet.
stockssn2o
May 25, 2015 08:54 AM
Wilson
Jul 21, 2002 05:08 PM
