SVO injector installation
Old Aug 18, 2003 | 08:02 AM
anaik's Avatar
I am in the process of installing #30 SVO injectors. I noticed when the injector is seated in the fuel rail, that is bottomed out, the retaining clips won't work. If I pull it out a 1/16" they will work. My question is, do they have to be completely in, or can I pull them out a little for the clips to work?
Old Aug 18, 2003 | 08:32 AM
Perry93TransAm's Avatar
I didnt use the clips on mine as well, I seated them fully then carefully placed the fuel rails on lining each one up with its appropriate hole tehn bolted down the rails. I havent had troubles yet.
Old Aug 18, 2003 | 09:44 AM
gb95zconv's Avatar
I used the clips....worked fine for me.
Old Aug 18, 2003 | 10:28 AM
m0nk's Avatar
as long as the gaskets are sealing when everythings bolted inplace you should be fine. The clips are just there for further saftey measures....
Old Aug 18, 2003 | 12:11 PM
anaik's Avatar
Well here's what I did. First I installed the injectors without the clips. I noticed that the o-rings where barely in the bores of the manifold. So I tried putting the clips on, but didn't like how far the injectors stuck out of the fuel rail. I noticed that the o-rings on the stock injectors where wider than the SVO's. So I replaced the o-ring that goes into the manifold with the ones from the stock injectors, they're fairly new. Seems to be a better seal.
Thanks for everybodys input.
Old Aug 18, 2003 | 04:45 PM
F-body Scotty's Avatar
i used a dremmel tool to make grooves on the injectors ever so carefully....and it worked.....they fit perfectly......however on the other hand i know people who have just slapped them in without the clips and had no problem at all......
rje
Sep 9, 2002 12:35 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
