SVO 30 lbs injectors
Old May 1, 2003 | 03:04 AM
93SS's Avatar
Will the LT1 fuel rail clips work with the svo 30 lb injectors? Thanks.
Old May 1, 2003 | 07:16 AM
Mr. T's Z's Avatar
I am sorry not trying to take over your post but I figured why bother with another one. They aren't to tall are they? Did a search couldn't find an answer
Thanks,
Tyler
Old May 1, 2003 | 12:34 PM
nateh's Avatar
You can't use them on the new injectors. The injectors work fine without them.
Old May 1, 2003 | 12:43 PM
smokindastangs's Avatar
so you don't need any other parts to install them?
Old May 1, 2003 | 02:28 PM
speedmiser's Avatar
Yes, your stock rail clips will work with the SVO 24 or 30# injectors, with no modification or additional parts.
But no, you dont need them. You can run the injectors without clips.
I'm running 30# SVO injectors on my 93. In the past I've used the clips, but at the moment I'm not...
13qtr
Oct 28, 2016 08:11 PM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
realistyc
Jul 28, 2015 07:32 PM
