svo 30 lbs ford injectors
Old Feb 18, 2006 | 04:13 PM
lr383's Avatar
A question for you guys who run these injectors. I quess you can not run the factory type clips on these 30 lbs injectors. I put them in but the bottom O ring does not go down in the manifold that far.Question is ,do they seal good enough ? or what do you guys do ? thanks for your help.
Old Feb 18, 2006 | 04:34 PM
Jameslt1TA's Avatar
Re: svo 30 lbs ford injectors
IVe got ford 36ers and they work fine with the factory style clips. Its ok they will seal fine.
Old Feb 18, 2006 | 05:22 PM
Quickss96's Avatar
were did you get the 36ers from? I have been looking.
Old Feb 18, 2006 | 05:24 PM
Cmr0z28's Avatar
www.summitracing.com
Old Feb 18, 2006 | 05:32 PM
turbo_Z's Avatar
I left the clips off and just centered the injectors the best I could. Worked fine for 3 years so far.
Old Feb 18, 2006 | 10:28 PM
rcmtby11's Avatar
i used the clips and the o rings went down fine with a dab of grease, you shoulnt be able to see the o rings or you will soon see gas. (i found that out before i used the grease to help get them in)
Old Feb 18, 2006 | 11:07 PM
SnakeOiler's Avatar
Mine worked fine with clips, too. If they are not seating, then you are not applying enough pressure. They should set properly. A dab of grease as rcmtby11 mentioned or slight tapping with rubber mallet should get the job done.
Old Feb 19, 2006 | 12:12 AM
Z95m6's Avatar
Except for that time you had fuel spraying all over your motor. No really they'll be fine. i think the fuel pressure will force the injector down into the intake and make the seal. Mine are fine but the clips wouldn't work with them.
Old Feb 19, 2006 | 07:12 AM
cehan's Avatar
I used the clips with mine. They didn't go down into the manifold as far as the stock injectors but they seal just fine.
Chris
Old Feb 19, 2006 | 08:53 AM
Kevin Blown 95 TA's Avatar
Chris
Same here.
KYWes
Jun 14, 2022 06:52 AM
Jul 17, 2015 02:47 PM
mrwz28
Jul 8, 2015 09:11 PM
