Suspension mods.....
Old Dec 9, 2003 | 08:38 PM
S.J.S.'s Avatar
K guys...my motor is done as you all know. I got my LCA's and brackets. I was wondering what are the first mods I should do for better handling. Not strip action but more for cornering and dare I say...road racing.
Old Dec 9, 2003 | 08:49 PM
Cmr0z28's Avatar
front and rear sway bars, adjustable panhard rod, subframe connectors, shock tower brace, (can get all of it from BMR) and bilstein shocks from www.bimmerparts.com
Old Dec 9, 2003 | 08:51 PM
fastbird96's Avatar
subframe connectors and a strut tower brace will definitely help tighten up the suspension
Old Dec 9, 2003 | 08:52 PM
Larnach's Avatar
Well dare I say, you made a bit of a mistake on the LCA relocation brackets. According to Sam Strano and some other hard core road racers, with front end modifications that will make the car handle significantly better, you will get oversteer with the lower control arm brackets. You will get a bit of roll-understeer with the front pivot point lower than the rear (axle mount), this will help promote a bit more stability in the turns.
A torque arm would help out a lot with acceleration, also sway bars, springs and damper setups are crucial. The compromise between race and street is made there.
Too bad you didn't wait for my LCA and Panhard rod kits... a couple board member are snagging the $380 kit for less than a $50 for testing.
Old Dec 9, 2003 | 09:47 PM
Cmr0z28's Avatar
Can you explain this to me more? I'm interested.....I know my friend needs an aftermarket panhard bar and upper brace to clear true duals over the axle.
Old Dec 9, 2003 | 10:00 PM
SmokinZtires94's Avatar
Ive got Springs, strut bar 3-pt , control arms, panhard rod, SFC's, tunnel brace, bushings, next and last will be a torque arm for more traction .... Of course im going for the 1320 .... for raod racing your looking into big time $$$$ for suspension ... adjustable everything, plus sway bars, shocks ect. hope you like to spend time looking underneath your car .... hahahaha good luck !
Larnach's Avatar
They are made of aluminum, QA1 rod ends, designed after Jon in the autocross forums design. Good for anything our cars can throw at them, you'd tweak the body before they would break.
They are quality rod ends, about $40 a peice, very nice peices indeed. Weighs in at about 8lbs lighter than stock for everything.
Old Dec 9, 2003 | 11:08 PM
S.J.S.'s Avatar
Well the way I figure...I got more problems with wheelhop than I do with ripping a turn at 80 mph. I don't do road racin but if I did, I'd want my car to handle. I tend to nail her every other weekend.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
mrwz28
Jul 8, 2015 09:11 PM
