Surging problem
Old Oct 3, 2005 | 11:42 AM
Cmr0z28's Avatar
Surging problem
Ever since I've gotten my car running w/the new trans, I've had a slight surging problem. Idle isn't rough, but at parking lot speeds (1-2mph), if I tap the gas and let off, the RPMs will drop when I let off, down to 200-300 and it will nearly stall, then the RPMs bounce up and down for a few seconds between 500-700. It actually stalled on me the other day when I tapped the gas backing out of my driveway.
I also noticed that while the RPMs are bouncing up down, the voltmeter fluctuates. I tried unplugging the MAF, and the problem seemed to get even worse. Any ideas what would cause this???
-Also, it behaves perfectly in neutral. It only does this while in gear.
Old Oct 3, 2005 | 11:46 AM
teke184's Avatar
Re: Surging problem
idle too low??
Old Oct 3, 2005 | 12:24 PM
cpt_bimes's Avatar
Re: Surging problem
^^your car is stock cam right? I just put a 3600 Yank in my car and my car sugres sometimes. Then it clears up. I'm thinking a tune will help the surging problems.
Old Oct 3, 2005 | 01:12 PM
Cmr0z28's Avatar
Re: Surging problem
Yep, stock cam. Motor is completely stock...valve covers have never been off.
You think it's converter-related?
Old Oct 3, 2005 | 01:58 PM
cpt_bimes's Avatar
Re: Surging problem
^yup. I've read too many posts on here not to think that.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
Noenav
Mar 1, 2019 07:38 AM
edman
Mar 13, 2015 09:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
