Surges during Accelation between 2k-3k Rpm
Old Apr 17, 2003 | 01:56 AM
crawl96's Avatar
Post Surges during Accelation between 2k-3k Rpm
don't know what to do.. replaced plugs wires, plugs, clean air filter, disconnected MSD Ingition system, reinstalled the stock coil, jack up the fuel pressure to stock 50psi. was set to 47psi. took out the Hyper tech III performance settings. added washer to the coil so it doesn't mount to the heads. Put Electro grease in each plug boot. the only thing haven't done, I guess would be the Optic spark or fuel Injectors. I'm I missing something? Help guys if someone experience this problem. Timing was up to 20 degree during Idle. Man I don't know.
Old Apr 17, 2003 | 04:08 AM
caliking97's Avatar
optispark
Old Apr 17, 2003 | 05:04 AM
Hyperspeed97z28's Avatar
whats your mileage? i'd say otpi as well
Old Apr 17, 2003 | 07:20 AM
93Z286Speed's Avatar
mine surges a little still and i just put a new opti in.. im thinking injectors.. only surges under light accel
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
