Super charger or 383 stroker
Old Dec 21, 2004 | 10:36 PM
97SLPcamaroSS's Avatar
Hey my name is kyle and i have a 97 Ltl camaro SS SLP which i have always wanted to supercharge it but then i got to looking arond for the best price and came across a 383 stroker kit. So my question would be what would be the best choice looking to run some where in the 11's. Need some help with the choice both would cost about the same because i dont want to distroy the orignal motor by boring out the motor. What should i do.
Old Dec 21, 2004 | 11:00 PM
firetird's Avatar
Re: Super charger or 383 stroker
IMO, the best choice for running 11's is not a stroker or supercharger. if you want to run 11's you should do heads, cam, and complete suspension. you should not have any problems breaking the 11's with those mods. the suspension, is the most important part of the setup. there is a guy that ran 11's on stock motor with all boltons and the right suspension.
Old Dec 21, 2004 | 11:18 PM
right now im in the 12.10 using nitrous but i really dont like using it to much not my type of speed im looking to go from 0-70 really fast not form 70+ with nitrous i want power i can play with but still go out to the track and run it and keeping in mind i put around 15000 miles on a year also keeping in mind its put away ever winter. Ya i do a lot of crusing.
Old Dec 21, 2004 | 11:33 PM
turbo_Z's Avatar
Either way youd be looking at building a new motor. Most guys who S/C are looking for something taht will run a lot faster than 11s. I say go with the 383.
Old Dec 22, 2004 | 01:21 AM
blwnlt4's Avatar
if you choose a 383 stroker you will have to bore it .040 over stock.
A 377 is a stock bore stroker and i think you would be happier with it for cruising.
Old Dec 22, 2004 | 09:07 AM
texasTA's Avatar
First off a 383 is a .030 overbore, not .040
I would suggest going with the stroker. Either way (stroker or blower), you WILL be rebuilding the motor. A blower will work with the stock bottom end for a while, but it will eventually take out the stock bottom-end. That is why I would go with a stroker. You can get a budget stroker for about 2500.00, then take the additional 1000.00 that ablower would cost and get your stock LT1 ported and buy a nice cam to go with it.
Old Dec 22, 2004 | 02:09 PM
blwnlt4's Avatar
but you can get a ''budget'' build for alot cheaper then $2,500 man. there are complete short block kits for $900 out there.
Old Dec 22, 2004 | 02:18 PM
texasTA's Avatar
You are right, I was quoting the price I was told by my engine builder for the Eagle fully forged internals, machining and assembly.
Old Dec 23, 2004 | 12:31 AM
Im not concerned with the money part ill be using the best of everything. My motto is "If your going to do something do it right the frist time" im not going to screw around with pulling out the motor to fix **** because i wanted to save a few bucks. Thats just the way i am planning on keeping the car the rest of my life. thanks for the help and more would be great too thanks
G-BODYT56
Jan 14, 2022 11:14 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
