Summit "House Brand" roller lifters anyone?
Old Jan 17, 2006 | 02:30 PM
edman's Avatar
I had a stock cammed 1995 Z28 that grew a flat spotted lifter and consequently grooved the cam lobe.I've installed a Comp 501 mild cam with Isky springs and stamped long slot 1.6:1 guided rockers.The lifters are replaced by Summit's house brand.Has anyone ever used these lifters before?They do NOT have the beveled edges at the roller like the stock ones, but still clear the lobes.Summit emailed me that they can rev to 6500,but my redline will be around 5600 anyway.The thing that I noticed is that the lifters have slightly shallower plungers which will make the pushrods effectively around 1/16th(almost) longer than stock.Will I run into a geometry problem?
My stock pushrods are the factory hardened versions which I do not want to replace unless forced to.So, in conclusion, has anyone had any experience with Summit lifters, and does anyone know the true manufacturer??
Old Jan 17, 2006 | 10:19 PM
musicman's Avatar
Re: Summit "House Brand" roller lifters anyone?
hopefully someone has had an experience to share with you, but i would say if nothing else call summit and they should be able to give you the information you need. good luck, itll all be worth it in the end.
Old Jan 18, 2006 | 12:00 AM
1racerdude's Avatar
Just get some stock replacements from the parts house like NAPA or Car Quest. Check to see who made them and if ya reconize the name like TRW. Don't get any made by lifters-or-us or **** Fu Enterprises.
Chevy dealer has them too and they are as good or better than anything out there.
Old Jan 18, 2006 | 09:17 AM
WS Sick's Avatar
Beware the federal mogul stock replacement lifters. I seen a set mushroom at the roller shaft area with only 300 #s of spring pressure.
Old Jan 18, 2006 | 09:48 PM
edman's Avatar
Back to the original question : has anyone out there had any experience with Summit's stock replacement roller lifters? Does anyone know who the hay makes them? I've emailed Summit several questions and they allowed themselves to answer only the rpm range question.
Also, when I removed my opti, I noticed that the shaft o-rings have disappeared into oblivian. How do I replace them? Do I use two that measure up from the o-ring bin at the parts store, or get part-specific o-rings, or forget about them? I removed the opti cap today and it looks very good inside. Just a little bit of trace oil because the pump shaft seal was leaking for years.
Old Jan 19, 2006 | 12:49 AM
imnotfast's Avatar
To anwser your questions. Only seen one summit lifter fail out of 10 or 11 sets.
The o-rings can be anyones that fits but i have been using Nylon washers that fit the groves.
Old May 26, 2006 | 07:16 AM
limige's Avatar
bump, looking to order a set today, anyone got anything else to offer?? $104+shipping seems too good to be true!
Old May 26, 2006 | 07:29 AM
Fbody1's Avatar
I know this is really not to help w summit lifters, but I got some off of e-bay (crane liftres) new, the seller name is bgater, they are great for $95 ,check them out. they are the same lt1 ,ls1 lifters .
Old May 26, 2006 | 07:49 AM
Javier97Z28's Avatar
Moderator
Installed them on an LT1 the other day.. they were fine as far as we can tell!
Old May 26, 2006 | 11:26 AM
brent95ta's Avatar
Just installed a full set on my car 3 days ago, so far they are working excellent.
Old May 26, 2006 | 11:32 AM
Tonedef's Avatar
i have them in my motor which is going in my car this weekend, so hopefully they're ok......I dont see why they wouldn't be.....
Old May 26, 2006 | 12:33 PM
tiznodd's Avatar
I installed them a while back and so far so good.
Slayer
Aug 17, 2015 03:55 PM
alphaauto
Jul 26, 2015 04:40 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
mrwz28
Jul 8, 2015 09:11 PM
