Stupid Water Questions...
Old Nov 8, 2006 | 06:13 PM
Jeremy95TA's Avatar
Stupid Water Pump Questions...
I've got a couple of stupid questions about my EWP install. I've got to press in the freeze plug into waterpump housing. The instructions recommend Loctite Sleeve/Bearing retainer. Is that just standard Blue Loctite? It also says Form A Gasket or RTV silicone. I have blue Loctite and I also have High Temp RTV. Are either one of those what is proper to use on the freeze plug?
Also, what is the best way to fill the car with coolent? It says don't run the pump without water for more than a few seconds. Should I just pour water into the radiator and let it flow through the system as it heats up or is there a better way to put water in?
Should I put any sealent on the gaskets between the pump housing and the engine block, or are the gaskets enough?
Sorry for the dumb questions, but I'm still learning.
Old Nov 8, 2006 | 06:31 PM
MeanGreen97Z's Avatar
I'm pretty sure the high temp RTV will work just fine.
I would fill the car prior to start up and as it runs add until it's full.
The gaskets should suffice.
No biggie. The community is here to support each other.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
colts0455
Sep 27, 2015 01:07 PM
NewsBot
Sep 14, 2015 09:20 AM
