Stupid water pump install question...
Do I need to put any kind of sealant on the gaskets or just install dry?.... I put them on dry, but now I'm wondering if that was right. I'm sure there are remnants of the old gasket still on. It was baked on something fierce,
Thanks,
Michael
Thanks,
Michael
Re: Stupid water pump install question...
Thanks,
Michael
Thanks,
Michael
Not a good thing.Those waterpump gaskets are less than 1/2" wide at the widest spot, and you do NOT want them to leak. A wire wheel and some gasket remover should make quick work of the old gasket. It MAY be ok for now, but you're probably going to end up with it leaking farther down the road.
I used RTV the first time, and spray gasket the second time. No leaks.
"gasket remover"??? I looked all over the auto parts place and found no such product. I tried WD-40 and a gasket scraper, and NO WAY was I getting it all off without slicing myself open in the process.
Should I pull the paper gaskets and just make a bead of RTV instead?
Which type of RTV? I haven't put the car back together, so pulling the pump now will be very easy.
Thanks!
-Michael
Thanks!
-Michael
Thanks!
-Michael
Thanks!
-Michael
Using a razor blade I haven't had any problems getting old gasket material off anywhere, even the deck surface of the block. If you don't feel comfortable that you got it all put a small application of RTV on each side of the gasket you are going to use.
