stupid question of the day.....
Old Jul 15, 2004 | 04:28 PM
30696bird's Avatar
I need to know where the O2 sensor plug is on the passenger side for an obdII 1996 firebird. I looked on shoebox's website but he has obdI so his is diferent. Where his passenger side o2 connection is flat, mine is square. I know I have a flat one somewhere cause my o2 has a flat conection. I have the driver side on.
Old Jul 15, 2004 | 04:30 PM
LWillmann's Avatar
I believe the passenger side front o2 clips below the manifold onto a little bracket bolted to the block. Look up from the starter and you should be able to see it.
30696bird's Avatar
Thank you I will look.
Old Jul 15, 2004 | 04:43 PM
30696bird's Avatar
It's not there. I just put the engine back in and can't find it. It's killing me, such a simple task and I can't do it.
Old Jul 15, 2004 | 05:33 PM
30696bird's Avatar
noone knows? The one by the starter(in the same cluster as the knock sensor) Is a square one.I need the front O2 plug that's flat.
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Brent94Z
Mar 21, 2002 04:44 PM
