Stupid question
Old Apr 28, 2005 | 08:25 PM
95 firechicken's Avatar
Stupid question
what tells the pcm to raise the idle when you turn on the air conditioner ?
Old Apr 28, 2005 | 08:28 PM
OBE1 95Z28's Avatar
Re: Stupid question
Your Idle Air Controller is always adjusting to keep your idle at the target value.
Old Apr 28, 2005 | 08:36 PM
Re: Stupid question
so if my idle drops low when I turn on my air and it never goes up I'm guessing the IAC is bad ?
Old Apr 28, 2005 | 10:21 PM
OBE1 95Z28's Avatar
Re: Stupid question
It could be that your throttle body, which houses the IAC, just needs to be cleaned. If the passage or IAC valve is dirty, it may be trying to let more air in, but can't flow enough. I'd clean your TB. Carefully clean the IAC valve, it's a delicate piece (mounts to the lower left front of your TB where the connector plugs in.
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Brent94Z
Mar 21, 2002 04:44 PM
