Stupid noise from engine!
Old Sep 29, 2004 | 08:44 PM
z71camaro's Avatar
From outside and under the car it just sounds like an exhaust rattle. It echos through the pipes. Using a mechanics stethoscope the sound is coming from the #2 primary. Sound from the primary is kind of a grinding rattling sound. So I pull the #2 wire, sound is still there. listen to valve cover and nothing. Nothing through the head or side of the block. The only place you can hear it is through the header primary. The sound speeds up with the motor.
Anybody have any idea?
If anyone can host a video I can get one.
Old Sep 30, 2004 | 06:00 PM
z71camaro's Avatar
Re: Stupid noise from engine!
Update:
The sound now quiets down when the plug wire is pulled but can still only be heard through the exhaust and nowhere else. It is a higher pitched grinding rattling noise.
Am I wrong to assume this is the #2 piston pin?
Fatdog2
Feb 12, 2015 12:24 PM
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 15, 2014 03:09 PM
squarehead
Nov 21, 2014 08:02 PM
Omega9
Aug 2, 2002 12:33 AM
