Stupid Hydraulic Roller Question
Old Jul 11, 2009 | 12:18 PM
95chwagon's Avatar
Do I need to use assembly lube when installing a hydraulic roller cam? My instructions cover hydraulic flat tappet and hydraulic roller setups, so I am confused.
Old Jul 11, 2009 | 12:30 PM
RamAir95TA's Avatar
Some people argue that motor oil is plenty on a HR. I used assembly lube on mine though.
Old Jul 11, 2009 | 12:40 PM
Rich2279's Avatar
Same here.
Old Jul 11, 2009 | 12:47 PM
95chwagon's Avatar
couldn't hurt, right?
Old Jul 11, 2009 | 12:51 PM
95chwagon's Avatar
My instructions also say to pull the inner valve spring (when running dual springs) when breaking in a cam. Never heard of this one either?
Old Jul 11, 2009 | 12:55 PM
RamAir95TA's Avatar
That doesn't make much sense to me.
Old Jul 11, 2009 | 01:13 PM
Stl94LT1's Avatar
I've heard to not use the thick assembly lube on the camshaft lobes, it will clog up the roller lifters? I used a 10w60 motor oil on the lobes.
Old Jul 11, 2009 | 01:14 PM
Stl94LT1's Avatar
This breakin method is used on flat tappet camshaft with high pressure valve springs.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Roadie
Feb 16, 2015 10:34 AM
Red_94Formula
Jan 22, 2015 12:17 AM
97_396_WS6
Aug 4, 2002 10:23 PM
