stupid 383 build questions
well i am going to have this car as my daily driver. Can i just bore it over and have the stock heads and just put better springs and rocker arms and pushrods in, i plan on putting a cc503 cam in it. do i have to stroke it too?
Re: stupid 383 build questions
Install a good set of 4.030" forged pistions, have some arp rod bolts installed on your factory rods, reuse the factory crank; that will be a fairly strong 355. Then have the heads proted by http://elliottsportworks.com/, the cc503 is a good DD cam. If you go 383 then I would not use one of those cheap cast cranks; the factory crank is stronger. For a DD build the budget 355 with le1 heads and cc503 cam will be just fine.
No use in going 383 for what you want. Get some .030 over pistons, have the stock crank and rods checked, reassembled with ARP hardware and let it eat. The stock crank is very good and the rods with good hardware are good to 500hp. If have the money, since you need pistons anyways, get some decent forged I beam rods from Scat with good bolts.
Keep the XE503 and matching springs [so long as they aren't spent], if you want more power Lloyd Elliott @ Elliott Portworks provides a great bang for the buck by porting stock heads. A XE503 with some LE1 or LE2 heads with a solid 355 bottom end would make for a reliable and quick car with good street manners without breaking the bank.
-Dustin-
-Dustin-
squirrels
Jul 13, 2002 01:58 AM
