Stumped
Old Nov 17, 2005 | 10:38 AM
fast96lt4's Avatar
Stumped
I have been trying to diagnose a problem and have gone nowhere. My headers glow red and my engine bay seems a lot warmer. I have done many things and it seems like if i have no progress to show for. I have a walbro 255,30lb injectors, opti-spark, msd coil,new ignition module, plugs/wires, and New 02's. Everything has about 2k on them and nothing has changed. Pcm is tuned by pcmforless so im stumped. Would loose or too tight R.R. cause this? The problem sucks, I have changed valve cover gaskets 2 times in 2k miles from all the heat, and i may have to buy new valve covers cause it seems like they might be starting to rust. What can be causing all this?
Old Nov 17, 2005 | 10:44 AM
Schweet97Z's Avatar
Re: Stumped
when headers glow red that means its running to lean. just because you got the tune from pcmforless doesnt mean the tune is right. everyone makes mistakes. i would call brian and see what he has to say. i say bad tune....
edit:....when you did the opti did you make sure you put the opti "in time" w/ the cam pin? if you didnt do that then you would be throwing spark at the wrong time to the wrong cylinders.
Old Nov 17, 2005 | 10:46 AM
blkchevyz's Avatar
Re: Stumped
have you checked your fuel pressure? fuel filter?
Old Nov 17, 2005 | 10:58 AM
fast96lt4's Avatar
Re: Stumped
Bryan has reprogrammed my pcm 2x and still the same so i rule bad tune out.The opti-spark is set-right.I Have checked fuel pressure. Set at 38 idle and 45 no vacuum for wot. What are the main reasons that cause lean conditions?
Old Nov 17, 2005 | 11:40 AM
blkchevyz's Avatar
Re: Stumped
are you getting a ses light?
check and make sure you dont have a vacume leaks.
you didnt keep your old o2s, might swap them on see if that changes anything.
Old Nov 17, 2005 | 11:58 AM
valter's Avatar
Re: Stumped
Actually, glowing headers can be a result from running rich. Unburnt mixture are still burning in headers. If your opti is on right, I'd try to readjust rockers.
Old Nov 17, 2005 | 12:23 PM
fast96lt4's Avatar
Re: Stumped
I will try to re-adjust r.r. and will also put new o2's on car, although i doubt it is any of these. This problem has been going on for a long time now, around the time i had my h/c put on. Would and can the timing be an issue?
Old Nov 17, 2005 | 02:42 PM
valter's Avatar
Re: Stumped
Definitely can be a timing issue. Do a search on "Glowing Headers", there alot of opinions on this subj.
Old Nov 18, 2005 | 01:44 PM
fast96lt4's Avatar
Re: Stumped
new o2's and still the same glowing. I will be re-adjusting r.r. over the weekend. What is the best way to do it?
Z28Freak86
Apr 30, 2024 05:37 PM
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
Xiantyl
Jul 21, 2015 05:42 AM
