stumbling solved, finally......
Old Jun 4, 2005 | 07:18 PM
Hawk's Avatar
After a long time of replacing parts and troubleshooting, finally solved my stumbling problems at low rpm at high loads.
Two problems, one was my A/F ratio guage was screwing up the signal wire to the PCM, the PCM never thru a code but it made the car pull timing and break up a little bit, and also run rich.
Second problem, My ignition box was wet and/or defective and caused a low end stumble.
For other people with stumbling problems, check your signal wire for your 02 sensors to make sure there isn't any noise on them.
I replaced many parts trying to fix this problem like the opti, wires, plugs, icm, coil, egr blockoff, etc.
Brian
Old Jun 4, 2005 | 10:35 PM
Rpm280's Avatar
Re: stumbling solved, finally......
Brian
How would you check ... with a multimeter, scanner , etc ?
What would you look for ?? What should one look for to tell if there is noise (interference)?
93 RedBird
Nov 15, 2015 08:24 AM
tommalcolm
Sep 11, 2015 03:39 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Strick
Aug 31, 2015 11:45 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
