Stumbling in high rpms...only at WOT
Old Oct 30, 2006 | 04:23 PM
RedRocketZ28's Avatar
To start things off my car only has 62k on it. I know that doesn't mean things cant go wrong but I wasn't prepared for them to start.
Anyway, lately my car has been cutting out at high rpms when going WOT. It wont do it every time, but when it does it, it makes a loud pop out of my cutout. Also when in neutral and I rev it up by going WOT it will cut out a few times when the rpms get a little past 4k. It usually does this every time. If I bring the rpms up without going WOT the car runs fine. What would cause it to do it only under WOT? Everything else is fine too, the car idles fine, drives fine in all other conditions, only at WOT in the upper rpms am I noticing this problem. Thanks for your help.
Andy
Old Oct 30, 2006 | 06:35 PM
mrmint69's Avatar
My car does the exact samething. I lived with it for 4 months and finally bought a fuel pressure gauge. When i really get on it the fuel pressure will drop to 0 for a split second. This is so common that there are 20+ things it could be. Does it do it when it is cold? This problem usually does not happen until the car is real warm. Fuel filter been changed lately? They this first. It's real easy and cheap. Also any codes? Then we will go from there.
Old Oct 30, 2006 | 07:46 PM
Thanks for the reply. I never get on it when the engine is cold so I am not sure if it does it then. Fuel filter has not been changed either. The check engine light will come on every now and then but that hasn't come on since the car has been acting up. It's just so strange that it doesn't do it all the time. Like I said though, when in neutral and I rev it up by going WOT it will cut out and pop almost every time and usually do it a couple of times between about 4k and red line.
Old Oct 30, 2006 | 08:22 PM
kline454's Avatar
sounds like fuel problem.
Old Oct 31, 2006 | 03:50 AM
wrd1972's Avatar
Mine had a very slight stumble around 5.5K RPM, it was very intermittant. Somene recently posted the exact same problem and found the screw holding the opti rotor on had backed out.
Right now I am pulling my engine and I found both screw halfway backed out and the only thinh retaining the rotor is the springy terminal on top. To me it sounds like ignition.
Rule out the fuel then start checking the opti.
Old Oct 31, 2006 | 09:16 AM
OBE1 95Z28's Avatar
Could also be spark plug wire related.
Old Nov 2, 2006 | 05:00 PM
I am not too savy when it comes to these cars. How hard is it to get to the Opti to check the screws? What would I have to remove to get to it and is it tough to even get to the damn thing?
Old Nov 2, 2006 | 07:39 PM
1994lt1z28's Avatar
my 94 did same thing very bad when hitting 150 shot of nos any how changed plugs wires nothing helped then i decided to change cap and rotor
and found that my opti was full of rust (thanks to the guy who sold it to me)
I only have 80k on mine so its not unheard of for low miles, new opti later
no stumble above 4k. changing it wasn't that bad about 3 hours total.
Old Nov 3, 2006 | 10:55 AM
blunto's Avatar
True. Check the simple things first. Have you verified spark at each plug? A tester is ~$3 at most local autoparts stores. With the cheap ones all you have to do is plug it into each ignition wire, clamp onto a ground, and watch for a blue spark while someone else turns the key to crank. AT LEAST do this test before you start attempting to take apart your distributor.
Also, if you feel that you are "not too savvy" when it comes to these cars but you plan on keeping yours, the investment in a shop manual is well worth it.
http://www.helminc.com/helm/product2...WERSEQU7P16DN4
Good luck & let us know
Old Nov 8, 2006 | 09:59 PM
I still haven't figured this out yet. Someone mentioned to try changing the wire from the harness to the opti. How hard is this to get to and where exactly is it? Also can I get it at any auto parts store or do I have to buy all new wires?
also, is this what I'm looking for?
http://cgi.ebay.com/ebaymotors/LT1-O...spagenameZWDVW
Old Nov 8, 2006 | 10:20 PM
87lt1rx7's Avatar
I had the spark plug wire cause high rpm stumble. it was soo bad and intermittent that i was forced to short shift at 4800 at the track
Old Nov 9, 2006 | 07:04 AM
Can someone please help me out with my previous questions? Thanks to all who have helped.
Old Nov 10, 2006 | 04:07 PM
blunto's Avatar
Shoebox's OPTI and Spark Test
The opti has two functions in the spark process. The first thing that happens is as the cam turns, the optical section of the optispark picks up the signals by the rotation of the shutter wheel. The pulses are sent to the PCM via the optispark electrical harness. The PCM processes the signals along with other sensor input and determines the proper time for the coil to fire. The PCM sends a signal to the Ignition Control Module (ICM) and it, in turn, causes the coil to fire. The spark from the coil travels through the coil wire back to the secondary ignition section of the optispark (cap and rotor), to be distributed to the proper cylinder.
If the opti is never sending the signal to the PCM, the PCM will never send a signal to fire the coil.
Here is some testing you can do. Refer to this diagram.
Disconnect the ICM connector. Leave coil connected.
Turn key to ON.
Check for dc voltage with a digital meter at harness terminal "A" to ground and and also "D" to ground. Note: Use a high impedance meter (at least 10 megohm) when dealing with the PCM.
Result should be 10v dc or more on both terminals. If you get no voltage, use the diagram and chase back toward the coil and the ignition fuse. Power for the ICM comes from the ignition fuse and through the coil, so any of that could be bad.
If you have good voltage, switch the meter to ac scale and connect test leads to terminal "B" and to ground. Observe meter while cranking the engine. You should see between 1 and 4 volts ac (those are the pulses that trigger the coil to fire).
If you don't see the proper ac voltage the problem could be the optispark, the harness to the optispark, the PCM or any of the wiring in between. Visually inspect all the connections you can get to for poor contact or corrosion.
edited 5/16/2004
Have you tried any of the other suggestions made to you? I have not seen your results. START by tracing your problem from cylinder ignition backwards. Let us know if you even have spark going to each plug and then we can work from there.
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
mrwz28
Jul 8, 2015 09:11 PM
