stumble what do you think
Old Apr 29, 2003 | 01:54 PM
flyingaaron2's Avatar
alright guys im posting again. i should be getting the car fixed within the next few weeks but i have a few questions. i just charge the A.C. in my car and when i turn it on the car stumble is 5 times worse. the rpms move all over the place when i have my foot on the brake. what the car is doing is when it warms up i get a bad stumble that starts around 2 thousand rpms. what do you think i should fix first then.\
its a 94 z28 auto.
Old Apr 29, 2003 | 07:51 PM
EvlViln's Avatar
Change your optispark, coil & Dwell module. Check your wires for arching and check you intake for vacuum leaks and your exhaust for exhaust leaks. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark. Replace you opti spark.
93 RedBird
Nov 15, 2015 08:24 AM
tommalcolm
Sep 11, 2015 03:39 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Strick
Aug 31, 2015 11:45 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
