stumble
Old Apr 18, 2004 | 07:35 PM
CLEAR's Avatar
stumble
for a while now my car feels like it has no power under 2k rpms. it feels like it is stumbling. i figure it could be plugs. now today for the second time i start my car after its sat for a while and the rpms are all over the place like it cant figure out where to idle. it also had a sort of loud pulley sound coming from the center of the engine...hopefully not the opti. anyways i let it warm up while its doing that then drive it and it eventually gets back to normal all day. help me out here guys because i want to solve the problem before i get stranded.
Old Apr 18, 2004 | 08:44 PM
Red95M6Z28's Avatar
Thats pretty much what my car is doing too. I just changed my water pump and opti and it DID NOT fix the problem. New plug wires tuesday we will see.........
Old Apr 19, 2004 | 09:35 AM
CrockRocket94's Avatar
check your Plug Wires... could be bad.
If you have headers.. could have burnt one.
if you dont... just check plugs and wires anyway, they were always my culprit.
Old Apr 19, 2004 | 09:42 AM
Red95M6Z28's Avatar
Yeah I am assuming mine will be plug wires becuase there is nothing else left to check! A guy I know had SLP headers and he burnt plug wires every other week!
Old Apr 19, 2004 | 09:52 AM
phibud72's Avatar
I had that problem before and new plugs and wires fixed it. Was a problem with hesitation between 1500-2000 rpms. Once i kicked it past 2000 it was fine. Check yer coil wire too.
-Phil
93 RedBird
Nov 15, 2015 08:24 AM
tommalcolm
Sep 11, 2015 03:39 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Strick
Aug 31, 2015 11:45 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
