stroker questions
Old Mar 24, 2007 | 01:20 AM
maro z28's Avatar
stroker questions
What usually comes in a stroker kit(rotating assembly)? Is it just crankshaft, pistons and rods? I was planning on either an Eagle or Lunati stroker kit(383). What else would I need? Studs or bolts? Caps?
Also, My 95 TA is a stock 2-bolt main. Is it possible, using my stock block, to convert it over to a 4-bolt main? Sould I do that? (a turbo i.e. over 500rwhp is not out of the question)
Old Mar 24, 2007 | 06:41 AM
Eric@Victory Racing's Avatar
Crankshaft, pistons, rings, connecting rods, main bearings, and connecting rod bearing usually come with a rotating assembly. You will need camshaft bearings, and ARP main studs.
You can convert your stock 2 bolt block to a splayed or straight 4 bolt mains. We use caps from Callies, but I believe they are just relabled Pro Gram caps.
Old Mar 24, 2007 | 08:37 AM
maro z28's Avatar
How much do you sells the Callies 4-bolt splayed caps for?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Newgmman
Feb 25, 2015 02:53 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
squirrels
Jul 13, 2002 01:58 AM
