stroker question
Old Feb 24, 2006 | 01:30 AM
  #16
Maldo's Avatar
Re: stroker question
Originally Posted by brokeTA
Well I had a customer buy cat 4 bolt main caps for his lt1, needed so much machine work to make them come close to to the crank main journal that he just threw them away and got eagle caps (no problems there). Then the last time we had a customer buy cat rockers put them on a set of ported lt1 heads with a gm 847 and it kept bending pushrods (so bad that the pr would fall down in the lifter valley and the rocker arm was just hanging loose) put a brand new set of cranes on it, and wallah no more probs. Then another time we used cat h beams in a stroked bbc. After about 6-8 passes we noticed oil pressure dropping off alot. Pulled the engine, and all around the rod ends and the cap was burnt black and smelled horrible, bought a new crank, eagle h beams, and once again no probs and still running the same engine (with a best 1/8 et of 5.91) for over 2 years now.
Eagle cranks & rods come from the same factory
I have been running cat stuff for a long time know no problems
Also have used their rocker arms on many cars without problems.
(Not sure how the rocker would cause a bent pushrods unless installed incorrectly can you say why you think the rocker arm was to blame)
As for the rods it seems to me what you described was in correct install or bearing clearance problems... again Eagle items come out of the same factory
Old Feb 24, 2006 | 09:10 AM
  #17
brokeTA's Avatar
You won't convince me that cat products are of the same quality as eagle/scat. There were no installation errors, the machine shop did the big block so I can't really vouch for that (just thought it was wierd that when the rods were replaced we didn't have the problem again). On the rockers, I believe they couldn't handle the lift of the cam, once again when we put good quality rockers on there they were fine. You can think whatever u want, I know I will not buy the cheap **** ever again (not worth my time, money or hassle)
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Newgmman
Feb 25, 2015 02:53 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
squirrels
Jul 13, 2002 01:58 AM
