Stroker kit on Ebay ...
Old Jun 22, 2004 | 03:28 PM
MarauderZ28's Avatar
Hi,
I deliberate upon the stroker kit for my camaro and I've found an interresting bid on ebay. Should you please give me advice, If it's good bargain? And which parts apart from mentioned should I need to complete the conversion? It's equipped with NOS now, and Powerdyne Supercharger is on the way so I need it to work together flawlessly.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33620
Thanx
MARAUDER
Old Jun 22, 2004 | 04:53 PM
tireburnin's Avatar
That short block is not built for a blower. It has a cast crank and 10.5 to 1 compression. Unless you are using some big combustion chamberd heads, that is too high for any sizeable amount of boost.
That looks to be a short block for a stout NA street motor. Compression is mid range and crank is cast. I would look into something built for your application. Save your money and buy the correct parts the first time.
Old Jun 22, 2004 | 10:24 PM
amean94ta's Avatar
i have a nib eagle forged assembly with 9.4:1 pistons $1,600 + ship
sean from
krs machining
D1SC383LT4
Jan 1, 2016 01:56 PM
Sauced
Apr 12, 2015 10:18 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
Redbird
Sep 14, 2002 09:18 AM
Redbird
Jul 20, 2002 06:08 AM
