Stroker is finally ALIVE!
Well It ran for the first time today. The stroker I spent all month building and putting in. It seems to been running pretty well, 3 minor problems. #1 the batter is sitting at about 11 volts even with it running. at 3000 rpms it is going to only about 13 volts. I checked batt - to engine block and its .8 ohms I think thats ok. most of the other connections look ok. The header AIR injection plugs are leaking a bit, I wonder if RTV or some sort of sealer should be put on them. Lastly it is surging a bit. I guess that is expexted with a CC306 and no tuning. Time to call madZ.!
