Stripped 2 threads on crank hub bolt...
Old Nov 7, 2003 | 10:27 PM
96 WS6's Avatar
Okay it's a long story but I was attempting to turn the crank to line up the dots on the cam/crank sprockets and I stripped the first 2 threads on the crank hub and on the bolt. The bolt is a grade 8 bolt 7/16 x 20 fine thread, 2.75" long. Nobody sells a bolt of that length. They have 2.5" and 3" but nothing inbetween. Where can I buy another bolt??? If I use a bolt of the exact same dimensions is it going to throw my balancing off or should I take a die to cut the threads into the stock bolt??
Also, I only stripped the first two threads. So would it be possible to try to thread in a new bolt and catch fresh threads or do I need to get a tap and tap the first two threads so another bolt will go in.
Please I need to know by tomorrow morning so anybody with experience please chime in!!!
Thanks in advance.
Old Nov 7, 2003 | 10:45 PM
I would use a thread chaser on the crank threads and check a local speed shop for an aftermarket bolt.
Old Nov 10, 2003 | 06:20 AM
IDOXLR8's Avatar
I am using a ARP crank bolt with some washer. Unfortunately the washer provided with the ARP bolt can be used because it will not sit down in the hub.
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
