strange noise from spec stage 3 clutch...
Old Apr 7, 2003 | 09:40 AM
blkchevyz's Avatar
first of all i want to say do not get the stage 3 carbon clutch unless you have to, its a pain to drive with.
after sitting in traffic for an hour or so the clutch started making a rubbing noise when i engaged it? well i went to go fix it today and it was gone?
anyone have an idea what it is?
Old Apr 7, 2003 | 12:37 PM
Camaro_SS/R's Avatar
The clutch took me about 1000 miles or more to get broken in and loose the chattering.
There is a trick I do to engage in first smoothly that is very helpful in the beginning. I rev it up to about 1.5-2k RPM then starts to engage. As it engage the rpm will drop, then rev it back up to 1.5-2k RPM again. Then release the clutch completely.
cheers
Old Apr 7, 2003 | 01:00 PM
blkchevyz's Avatar
yeah i've gotten better at driving it, but its still a pain. specially going from my daily driver(99 mustang) to the camaro.
i still wish i knew what that noise was, i dont know if i should pull the tranny back out or not
Old Apr 7, 2003 | 01:07 PM
1997rblckSS's Avatar
cheers
I agree, I did that for a little while, after I ran mine at the track though, I haven't had any problem since and drivability has been wonderful.
I can't explain the grinding noise, seems like you would have to be there and hear it yourself to be able to really determine what it is. I can understand though wanting to know what it is due to not wanting to cause any harm.
Hopefully it will be one of those things that will go as quickly as it came.
Old Apr 7, 2003 | 04:21 PM
blkchevyz's Avatar
i guess i'll just drive it and see what happens, i really dont feel like pulling it back apart
Old Apr 7, 2003 | 05:30 PM
Ryan 97 Ram Air T/A's Avatar
Is the chattering only when you are in neutral? A lot of high performance clutches do that when they are not under load. I'm not sure what does it, but it is pretty common. Even on full race cars.
Old Apr 7, 2003 | 05:38 PM
funina91ss's Avatar
I would get a rubbing noise in mine when backing up a hill or sliping the clutch alot.. it would go away after a few miles .. the best thing I ever done for drivabilty was 4.10's you could just almost dumpt the clutch and the car would start to move and wouldnt chatter..
Old Apr 7, 2003 | 06:06 PM
Lost's Avatar
You just need to get used to the clutch.. MY GF drives a 2001? V6 stang (meaning I drive her around in it) and I've grown to prefer the short harsh engagement of the stage III carbon (I have the older version too) over the long engagement of the mustang (it feels like I'm slipping it too much).. just give it time and you'll get good at it. I consider mine an anti theft device since no one but me or my GF can drive the thing
As for the rubbing.. well on engagement from a stop I'll get a loud squeek kinda noise.. it may be the torque arm rubbing on one of the bullet mufflers though.. I need to take a look at it.
HTH
Old Apr 8, 2003 | 11:55 AM
blkchevyz's Avatar
cool i wont worry about it then.
i probably just need to drive the car more, i dont even have 300 mile on it.
Old Apr 9, 2003 | 10:32 AM
fbird95's Avatar
My car does that rubbing non-sense only when its cold, once its warmed up it goes away. I've been told its the throwout bearing, but i'm not gonna worry about it.
Nayr
Mar 3, 2023 08:34 PM
Quickss96
Jan 29, 2016 05:56 PM
tdigger9899
Sep 7, 2015 10:56 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
karpetcm
Aug 14, 2015 03:02 PM
