straighten steering wheel with ?
Old Apr 13, 2003 | 03:07 PM
rckrzy1's Avatar
After aligning my car at a good frame shop they got the wheel off to the left by about 10 degrees,can i just change the tierods an even amount till it's right? As in go 1 turn to the left on each tierod till it's straight? The car tracks pretty good. I just hate to spend the time at shop.
Adam
Old Apr 13, 2003 | 03:23 PM
Rodrigues's Avatar
If they didn't align your car right go back and have them do it right for free.
Old Apr 13, 2003 | 03:31 PM
You are correct that the tie rods control the position of the steering wheel. Your shop shold have centerd it for you-that is part of the alignment process at any decent shop. they should take care of it for you.
I don't recommend moving the steering wheel on the steering shaft. Your car should be in the middle of the steering rack when the wheel is straight ahead. Let the shop fix it as it was supposed to be.
BTW, I have done what you were suggesting and it worked fine for me. Just be very exacting.
Old Apr 13, 2003 | 04:06 PM
ChickenScreamer94's Avatar
shoebox, i have the same problem as rckrzy1, and was wondering how you did that tierod move thing you were talking about. did you just jack up the front end? how do you know how far the tie rods can go?
Old Apr 13, 2003 | 04:12 PM
Lunarson's Avatar
I'm having that problem with mine too. When driving straight the steering wheel was tilted to the left. Well I've had it aligned twiced from two different places and it still rides that way. I tried to reposition the steering wheel on the shaft and it ended up being off the same amount in the opposite direction. I attempted to do the tie rod procedure but was unable to break the nut loose on the tie rod end. I think I'm gonna load it up with liquid wrench or something and try it again though.
Old Apr 13, 2003 | 05:34 PM
rckrzy1's Avatar
Talking
I got it straight and for those interested I went 1 full turn and it over corrected, I had to go to about 3/4 turn for a 15 degree offset.
jasonduaine
Jun 4, 2015 09:29 AM
CheckOutMyRoost
May 23, 2015 02:33 PM
nikko
Apr 28, 2015 10:05 AM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
