Stock windage tray removal
Old May 10, 2007 | 08:52 PM
chas010's Avatar
Hey everyone, i have a quick technical question for you guys. I purchased a Milodon 30909 oil pan for my 95 z28 and was curious if i should remove the factory windage tray when installing this pan with the built in windage tray? if i remove the factory windage tray is there a chance of me inadvertently loosening the main studs when removing the tray nuts? thanks jason
Old May 10, 2007 | 09:17 PM
bingo's Avatar
There is no way you could loosen the mains while removing the tray. The studs are way too tight for that.
Old May 11, 2007 | 12:58 AM
seawolf06's Avatar
You won't loosen the mains that way. If it says to remove the stock tray, then you should do it. If you think it should stay on, then call Milodon and ask.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
adam85
Parts Wanted
Jan 1, 2015 02:24 PM
ddr698
Dec 31, 2014 09:16 AM
