Stock Waterpump Vs. Electric Wp
Old May 18, 2003 | 07:05 AM
  #16
baron4406's Avatar
I have a CSI waterpump on mine and it was a great mod. I only drive my car occasionally. The car runs MUCH cooler with the CSI in place.....in fact it runs so cool the heater only works so-so in the winter. This is fine with me because I'm eventually gonna install a big trans cooler which will block some of the flow from the radiator, that would have killed the old setup. Also its awesome to be able to have your car ice cold after every run while drag racing. You just sit there with the waterpump and fans running until she's cool.
Old May 18, 2003 | 09:10 AM
  #17
dreamer1q's Avatar
I run the Mez, and have no complaints. It keeps the car WAY cool, and really is a breeze to swap. Keep a spare in the truck, I do. I also setup a little tool kit that has everything I need to change it in the trunk. I drilled two holes in the dash between the HVAC controls and the speedo and installed 1 red and 1 green LED with built in resisitor. Wired the green on to the ground of the pump, and the red one to the power on the pump. If I lose power or ground at anytime, I lose the light on the dash. That way I know it always has power. Other then that, it is like any other pump. Check your water temp from time to time to make sure all is ok. And the ability to turn it on when the car is not running makes for cooler track runs, and burping the system is a breeze. Most guys run the car for like 45 minutes to get it burped. I had it all done in under 10 minutes with the electric pump.
Q
Old May 18, 2003 | 09:20 AM
  #18
94Sleeper's Avatar
Originally posted by Formula_one
What side of town are you on? I've got a formula as well, I'd be interested in checking yours out...
I'm on the far west side. West of Silverbell off of Sweetwater between Grant and El Camino Del Cerro (Ruthrauff). Car is on jackstands right now awaiting heads. I'll be working on it most of next weekend to get it back on the road.
Old May 18, 2003 | 06:11 PM
  #19
Formula_one's Avatar
I'm on the far east side. Lemme know when you get the car back on the road or if you need a hand! It wasnt that long ago I had my motor apart...
canbaufo
May 25, 2015 12:01 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
