Stock valve spring questions
Old Oct 23, 2006 | 08:03 PM
BadBowLT1's Avatar
does anyone know what the stock valve spring installed height is? and how much lift they can take? and the outside and inner diameter?
Old Oct 23, 2006 | 08:26 PM
RE AND CHERYL's Avatar
Re: Stock valve spring questions
All I know is max lift is around .490. Just low enough to preclude the safe use of 1.6RRs on the stock springs.
Old Oct 23, 2006 | 09:43 PM
94CamaroZ28's Avatar
Installed height is 1.78. Max .485-.490 lift. Pretty much any mod will require at least the LT4 valvesprings, and those are good only to .525.
My suggestion: look at the Patriot Gold dual springs. With many aftermarket valves you'll need -.050 locks, but they include 10 degree locks, titanium retainers, seats, and springs good for up to .660 lift for $250 or so.
Shim and adjust installed height to desired seat and open pressure. Light seat pressure may require machining the spring seat area, especially if you need to use -.050 locks as I did to get enogh tip height for my self-aligning roller rockers.
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
