stock timing chain ok?
i just recently put together a 383 bottom end with le2 top end package etc..
just wondering what timing chain to get? i dont know if stock timing set is suitable or not due to the engine probably having around 425 RWHP..if not please give me a recommendation...must be 93-94 style with the splined opti drive..thanks
I personally would up grade to the 95+ style timing cover,95+ opti, 95+ cam pin, EWP, and a true double roller. Or bear minium, minus the EWP, and the true double roll up grade to the LT4 HD with the 95+ stuff. If you spending the money on a 383, it would be cheap insurance.
yea, ive seen some of the highest quality parts fail..i only asked this question because i seen there wasnt much selection for 92-93 timing set. i see a majority of you guys are running oem style timing sets, so i guess thats what i will run. how many miles do you guys that are running this set have on your engine?
