stock thermostat?
Old May 1, 2009 | 11:07 AM
Tanner_94_Z28's Avatar
stock thermostat?
does anyone know the stock temp setting on the 94 camaro z28 thermostats?
im interested in getting a lower temp thermostat...i heard it was 200 and if so i was goin to change to a 180 thermostat.......
Old May 1, 2009 | 11:28 AM
moparman's Avatar
Stock thermostat is 180.
Old May 1, 2009 | 01:25 PM
bombebomb's Avatar
If you are changing it, you might as well go with a 160, otherwise the difference will be minimal.
Old May 1, 2009 | 01:49 PM
RamAir95TA's Avatar
Changing the thermostat alone won't help a thing. It will only help when used in conjunction with a manual fan switch and/or earlier PCM cooling fan activation (from a PCM reprogram).
To clarify, the 160 thermostat does nothing by itself, except make your car take longer to warm up.
canbaufo
May 25, 2015 12:01 PM
grgguy
17
Feb 23, 2015 07:57 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
cmdeshon
Dec 27, 2014 10:06 AM
