Stock Spring Replacement?
I am sure there are threads already on this, but since the search appears to be broken, I'll ask.
I race in the Camaro-Mustang Challenge series and have to run stock valve springs or stock replacements.
Where would you buy them... Autozone, GM dealer....etc. ?
Is their a site that has instructions for changing them on the car?
Thanks,
James
Thanks,
James
Shoebox has a tutorial on his site that goes over a valve spring swap: http://shbox.com/ci/valve_spring_swap.html He also has the contact info for Jason or Dal who can get you GM parts at wholesale. Also, GMPartsdirect should have stock replacements.
http://www.shbox.com for instructions
gm dealer for parts, or try gmpartsdirect.com or gmperformanceparts.com
Edit - Oops, I'm too slow
